LabVIEW has a nice feature allowing an arrow to be drawn from a comment and attached to a block diagram element. This makes commenting specific parts of code much more precise. The Functional Safety Editor lacks this feature (and is inefficient to comment in general). When adding verbose comments to the diagram, it can be unclear which comment belongs to which state or transition.
The proposed idea is to add the same comment/arrow functionality from LabVIEW to the FSE, so comments can be attached to a transition, state, compound state, etc.
