Additional NI Software Idea Exchange
Automatons
Hierarchical State Machine Object (HSMO)
Status: New
Powerful of Hierarchical State Machine Handling with GOOP Fully Implementation
https://github.com/saosawas/LabVIEW-Hierarchical-State-Machine-Object
{Feature}
-> Precompile Source Code for maximize performance and Fully OOP Implementation
-> Dual option License mode (Free / Commercial) normally use Free mode , if some time need to protection using Commercial mode the Framework will require Activation Code.
-> All Sub Class(Inheritance) only Call Parent and no need to additional Coding, so It’s improve mistake and reduce Develop time
-> Higher Runtime version support , this framework is able to run with higher Runtime version , no need to re-Compiler on the future
-> Memory Safe and Faster with DVR Encapsulation , All State Object is reserved of independent memory (Crash & Malfunction Guarantee)
-> Terminate Wait Milliseconds or Delay Function with State_Interval Class and State Timeout, So the All Tasking is execution at the same time and monitoring with own clock
-> Light weight and Overhead less
#HSMO
