When using the Read/Write Variables to INI File step in VBAI and not selecting the Ethernet option the code that is generated still includes this step and therefore requires the Ethernet IP toolkit to run the code. I suggest that when the box is uncheck then the generated code not require this toolkit becuase the VIs are going unused.
