Make the Measurement & Automation Explorer ( MAX ) Import Assistant Window resizable, because now not all informations are visible to the user:
This is not at all related to LabVIEW. MAX has it's own Idea Exchange.
You can now resize the Export/Import dialogs as of MAX 5.3 (summer 2012).
...so if the dialogue boxes of MAX are resizable now, I would consider the status of this idea as completed (not new)...
