Hello NI guys,
I want to know when NI will develop a better software than MAX, each new release is more unstable than the previous one.
With the release 5.1.0f0, each MAX execution starts or stops by a crash. It's totaly unusable.
I want to change the name, it hangs !
I want to see the boards on the target, it hangs !
I don't know why it hangs, I can use a computer with only NI Products and nothing else, it will hang on each time.
I'M NOT ALONE IN THIS CASE !
Please hurry up and develop a new software to setup the target !!!!
Best Regards
CFOE
