For a reason I don't know, NI Softmotion team remove the function "write position setpoint" to all 951x axis. I'm using four (4) 9514 axis right now that all need to use this function at sometime in my code.
This function is really useful when design a motion tracking system and also for PID tuning to check step response.
I can't upgrade to LabVIEW 2018 for this reason without non-desired work-around.
Please work on reenabling this fonction on all 951x axis.
