I have many procedures that check for certain conditions before completing its intended function. If a precondition is not met, the procedure exits. It'd be nice to be able to pop up dialogs as necessary. Right now, in order to do so, I have to have the procedure call other alarms if I want any sort of feedback/popup which gets convoluted pretty quickly. Thanks.
