I have a system definition of over a thousand signals. I see that VeriStand 2011 has some search functionality built in. Is there a way to search not just ni the channel names but for the use of particular variables within calculated channels? For example, if I have UserVar1, I'd like to be able to find all occurrences of where UserVar1 is used. It could be an argument in a Calculated Channel, a mapping destination, an alias, etc. Is there a search tool that can accomplish this? Thanks.
