When migrating to a new server with an updated license File I loaded a large backup files from a server with a 1000+Computer based licenses. The process of loading the back up took around 1 hour, which got me unsure if the process of restoring the backup was going correctly or not. It doesn't has a loading progression bar to see how much time left is needed for the backup to finish, or even just a progression bar of the percentage left. In the end the process was successful, but very stressing... I think having a progression bar would be an excellent feature to have.
