right now, if I invoke nivlm.exe /exportClientPermissions C:\foo\bar.txt, I don't get any information about disconnected licenses.
It would be great if it had a column for disconnected license expiration date associated with each item (that would be empty/null if no disconnected license was assigned).
Would also be helpful if there was also information about home use licenses grated against a user.
