Currently, our NILM license daemon doesn't support the TIMEOUTALL function when used with a FlexNet server. The purpose of the timeout is to cause an application to release its license if idle, which is useful in the case that a user doesn't realize LabVIEW or another NI program is still open on the client machine. The TIMEOUTALL command is a standard FlexNet option.
It would be useful if we provided this function, or provided a similar function in the Volume License Manager server product.
