Aside from the fact that most of the errors are just pulled up from device drivers which makes them vague and not at all related to the actual VeriStand function happens (so part 1 of this feature request is an overhaul of our error reporting in VeriStand), it would be great if it actually logged these or gave you the option to save to a file. This means that you can then send this to NI Support for assistance or at the very least, document issues.
