Today we need to configure the hardware in MAX and in System Explorer.
Allow VS to import the hardware configuration from MAX and eliminate the DIO number of ports and port size manual definition.
I guessed the PXI2569 and PXI2570 configuration in a trial and fail matter till I found the number that did not cause an error during deploy.
Import all board I/O configuration and let the user remove what is unused later.
Cheers,
CHCastro
