Advanced Plotting Toolkit
Colorbar Scale (ADVANCED PLOTTING TOOLKIT)
I'm using a Filled Contour Plot (started with example provided); Any idea on how to set the colorbar scale manually? I can set the colormap min & max, and this color translates to the colorbar colors, but not the numerical values on the colorbar.
Background: I want to compare, side-by-side, filled contour plots, but want the colormap, colorbar, and colorbar ranges to all be the same (better visual comparison). Without manually setting the ranges, each plot is auto-scaled based on data maganitudes (and color ranges end up being simular, even though magnitudes are different). I can do this with an array plot, but don't get the crisp contours.
Thanks in advance for any help.
Message 1 of 1
(4,879 Views)
