Received this error message when trying to run a program written in Labview 8.6 for earlier CAN i/o that worked fine until a dual port PCI CAN board was fitted that needed XINET.
I have Max 5.1 installed with Can 2.7.3 and XNET 1.5 with the earlier can support installed as per the NI migration document. Carried out a search on this error but cannot find anything.
The header of the message is:- "Error -1074384579 occurred at CAN initialize.vi"
and then:-
"NI-XNET (Hex 0xBFF6313D) The object name contains unsupported characters. The name musr=t contain just alphanumeric characters and the underscore, but cannot begin with a digit. The maximum size is 128".
Labview Version 8.5
Labview Version 8.6
Labview Version 2014
(6,350 Views)
can you add an IO Trace Log file to this post
(6,347 Views)
NiTrace attached,
Labview Version 8.5
Labview Version 8.6
(6,344 Views)
Sorted, a couple of underscores were missing between description words in CAN database. Strange that it worked with previous setup?
Labview Version 8.5
Labview Version 8.6
(6,339 Views)
