i work to make a sequence of test for an electronic unit (for an automotive application). The I/O with the unit
is made by a 6025e board and a CAN board (2 port sw selectable). Sometimes, after a random number of test
(between two consecutive test i turn the key off, and the unit shutdown) i receive the CAN error:
Error -1074388885 occurred at CAN Write (Multi-Chan Single-Samp 1D Dbl).vi
Possible reason(s):
NI-CAN: (Hex 0xBFF6206B) CAN bus problems (no ack) caused all communications to stop. This error corresponds to CAN Bus Off state. Solutions: Verify that cabling is correct, devices are connected and operational, and proper bus power is applied.
I don't understand why, there aren't a "time rule" that help me to understand, because the error sometimes
appear, sometimes not, sometimes after few test, sometimes after many test, and there aren't a group of test
that specially put this error.
Someone have the same problem or know the reason (and the solution)?
I don't work with th CAN communication from much time, but i think that probably the error appear because the
CAN card have a several behavior, much more rather than teh unit (the unit support the no-reception of a
certain number of frame, perhaps the CAN card not).
