52bit signal limit on CAN frame
Is there a way to overcome the 52bit limitation on CAN signals?
Why is there such a limitation?
Luca
(5,900 Views)
Hi Luca,
you can find more information here.
I hope this helps!
Bye,
Licia
(5,886 Views)
I understand, but that limitation is only present on NI CAN solutions. Being incompatible with the most widely spread automotive dbc standard (i.e. Vector) is a big problem.
Thanks anyway.
Luca
(5,884 Views)
