8476: Can I send an incorrect or custom checksum with a LIN frame?
I see the option to choose classic or enhanced checksum with the NI USB-8476, but is it possible to specify my own checksum?
I want to look at a response to a frame sent with an incorrect checksum.
(7,261 Views)
Accepted by topic author johnoca
You cannot specify your own, but if your slave is expecting enhanced, you can send classic (or vice versa) and it will be incorrect.
(7,256 Views)
I am using a NI 8476 LIN Interface.
I wonder if it is possible to send a full frame with an inverse checksum. (sum of bytes)
Actually if it is possible to specify you own checksum...
Thank you very much,
Cristian
(4,844 Views)
