9862 module compatibility with DAQ Assistant
I couldn't find the answer anywhere so I was wondering if I could use the DAQ Assistant block with my NI-9862 module. If not, I will use the XNET library.
(2,739 Views)
Accepted by topic author vboulanger
The 9862 is not a DAQ card, so it doesn't work with DAQmx, and doesn't work with the DAQ Assistant.  Look up various XNet examples and you should get an idea of how to use the hardware.  They are in Help >> Find Examples.
(2,728 Views)
