Accessing CAN-Device using CANopen
Hi Thomas,
Yes the first byte specifies the command which is defined in the CANopen spezification. See the following link:
Link
To your second question: It depends on the speed you need for the SDO. I prefer to use a sub VI (see attached) to write and read SDOs.
In this Case you got  the message directly , without any poll.
What kind of data are you reading there? perhaps it is easier to use a PDO?
DirkW
Message 11 of 15
(2,632 Views)
Hi Dirk
I have to read about 10 different values. Most of them are serial numbers of different items. I don't have to take care of speed as this process is taking place after a tool test with a duration of about 30 - 45 minutes.
Yes a sub vi is what I also wanted to code. I'll have a look at what you've posted and give it a try.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 12 of 15
(2,630 Views)
Hi Dirk
I had a look at the vis you posted and modified them a little to meet my needs. I just tested them on the testrig - it worked. Exactly the way I wanted it.
Many thanks - you helped me a lot.
Thomas
Using LV8.0
Message 13 of 15
(2,600 Views)
Hi Dirk
What would be the difference if I use PDO? And how would I have to do it?
Thomas
Using LV8.0
Message 14 of 15
(2,568 Views)
Hi Thomas,
The profile (DS301...) normally defines the mapping and so you can find the default mapping in a way that PDOTx 1 is for digital Input and Rx1 is for digital Output and PDOTx 2 is for analog Input and Rx2 is for analog output. This is done, if you have such I/O available. But you can map these PDOs by your own, using SDO commands. Attached you can find a manual for the WAGO CANopen system. This manual describes the use of the different SDOs to map a PDO  I/O.
I think thats easier for you to understand and should clarify the way to go.
DirkW
Message 15 of 15
(2,560 Views)
