Analyze CAN Bus with NI XNET
Hi all,
I work with an NI-PXI-8512 and LabVIEW Components fro the  NI XNET palette (LV Version 2013).
Communication over the Can-Bus functions very well (it's an automated test for software components).
Now I would like to get some data like busload, amount of error frames e.g. .
Does someone has some experience with this?
Thanks for your answers!
(9,173 Views)
Hi dfschunk,
error frames can be read since the NI-XNET 1.7 driver. There are 2 options to read the error frames:
1. bus monitor:
Launch the bus monitor (start/all programs/NI XNET/). Start the feature: interface&database from the symbol bar, choose your CAN HW port. Now you can also select error frames.
2. LabVIEW VI
Error frames can be read, if you insert a XNET propertynode:Bus Error Frames to Input Stream. I attached a screenshot therefore.
The bus load is shown at the bus monitor.
Kind regards,
RupiDo
@dfschunk wrote:
Hi all,
@dfschunk wrote:
Hi all,
(9,123 Views)
Hello everyone,
I am working with the same board PXI-8512, but when I start Bus Monitor i cannot see the interface CAN0,CAN1 (the way I named them on the MAX). I read others  old post and they said that it was not possible to use this program with a PXI or Compact RIO Board. I would like to know if it is possible.
I'm using Labview 2010 32 bits, i have the XNET library installed, but i used the CanOpen Library to communicate with a Motor Drive.
Juan Carlos Cambera
(8,938 Views)
Hi I also want to know how to monitor the CAN busload with NI XNET?
(6,481 Views)
