Arxml in xnet not showing all signals
Hi All,
  I tried to implement signal transmission in labview using xnet api pallete but while opening the arxml and trying to see the signals but I could not able to see all the signals, only 422 out of 530. So please anyone let me know, whether any settings required. I am using the latest NI XNET Software licensed one. Please anyone can support in this issue it will be useful for my project. In that i tried to check in XNET database editor, where some signals are missing.
(1,518 Views)
NI-XNET has limited support on the ARXML database. It is recommended to use the NI-VCOM. You would need a full edition to use ARXML database. Once you have the VCOM installed, use the Web UI to browse the ARXML database.
Does NI-XNET Support the Database in AUTOSAR XML Format?
https://tmesystems.net/
(1,508 Views)
