Baudrate Range
I am using NI PCMCIA CAN /2 with the part no.of 188520B-02.
Can anybody tell me what is the baud rate range of this card?? i am getting error if i use 500Kbps.
Regards
Meenatchi
(6,975 Views)
It could be that this board is low speed only or a dual speed with one port high and one port low speed. Open the Max Tool and left click to your ports or have a look to the transceiver dongles.
DirkW
(6,971 Views)
Thanks for reply.
Can you please send the datasheet for NI PCMCIA CAN/2
(6,956 Views)
Here is the datasheet. Make sure you have the latest NI-CAN driver installed.
https://www.ni.com/en/support/downloads/drivers/download.ni-can.html
DirkW
Message Edited by DirkW on 05-12-2008 09:27 AM
(6,946 Views)
