Blinking code 0x24 reported from USB-8473
Hi all,
I use USB-8473 (CAN bus) for monitoring parameters with our product that applied on engine control.
Everything works fine when engine stop, but USB-8473 always reported blinking code 0x24
(2 slow blinks followed by 4 fast blinks) when engine is running.
I cannot find any information about blinking code 0x24 on NI website or NI-CAN manual.
Can anyone helps?
Eric
(3,990 Views)
2 slow followed by 4 fast doesn't appear to be a valid error code. There are multiple LEDs on the 8473, can you specify exactly which LED is flashing this pattern?
Jeff L
(3,962 Views)
The closest fault to this pattern I can find is related to a power failure condition on the CAN bus. If the voltage on the CAN bus drops below a threshold during operation it will cause a fault. Can we monitor the CAN bus Vsup to verify it stays within acceptable limits and/or power the bus independently from the engine?
Jeff L
(3,957 Views)
Hi JefeL,
Thanks for your suggestion, I will check CAN bus Vsup.
By the way, the status code 0x24 was reported by "USB" led on USB-8473.
Eric
(3,945 Views)
Hi JefeL,
I attached a picture when connection failure occurs.
Yellow line - CAN bus Vsup in the product side.
Green line - CAN_LO
Pink line - CAN_HI
It seems CAN bus Vsup is operate correctly.
Both CAN_LO / CAN_HI present voltage drop.
Can you help us ?
Eric
(3,910 Views)
Hi Eric,
I found the error code pdf here:
http://download.ni.com/pub/gdc/tut/nican_errors_en.pdf
(referring to "BFF62024" in the pdf)
it seems that 0x24 means a bad handle was passed to the device. Most likely the source of this error would be when the CAN device is actively running and the host computer is suspended or put to sleep.To recover from this error, you probably need to notify the host that it needs to close and re-open the CAN connection.
(3,708 Views)
