Block Diagram of 2 port PCI CAN Card
Hi
Can anybody send the Block Diagram of 2 port PCI CAN Card as well as PIN Configuration. Please send it as soon as possible .
It is very urgent.
(5,409 Views)
The pinout can be found on page 4-1 of the NI-CAN Hardware and Software Manual that is installed with the NI-CAN driver at Start >> Programs >> National Instruments >> NI-CAN.  I'm not sure what you mean by the "Block Diagram" but the manual has various diagrams of the board, bus, trigger lines, switches, etc.  What information do you need?
Robert Mortensen
Software Engineer
(5,400 Views)
Hello Robert
Diagram given in the  NI-CAN Hardware and Software Manual is the PIN Diagram. I need internal Block Diagram of the 2 port NI CAN card.
Which explian the internal circuitry like CAN Transceiver  & CAN Controller .How they communicate to each other etc.
If any body can send this block diagram to me.
Thnaks
(5,395 Views)
Unfortunately that information is unavailable.  All the information we have released along those lines is included in the manual.
Robert Mortensen
Software Engineer
(5,389 Views)
Why do you need this information? If there is something in particular you are looking for, it may be answerable.
(5,388 Views)
Hi
Sorry for late reply. Actually I m using PCI CAN card first time.So i just wants to know , how the communication between  transceiver and CAN controller takes place.
Regards
Raman
(5,299 Views)
Hi Raman,
In general, the CAN controller gets a message from the CAN transceiver, which is put into an output buffer. Then an IRQ line is set to signal the CPU that a new CAN message is available. I've also provided some information about CAN that you should find useful.
Controller Area Network (CAN) Overview
Ebele O.
(5,284 Views)
