CAN Channel method Crash LabView
Dear All,
I'm working with :
- Labview 8.2.1
- Windows XP SP3
- Driver NI CAN 2.6.3
- PCI CAN Serie 2
- Multifonction DAQ
I have build a program who's measure at same time DAQ MX Analog measure and CAN Channel measure. For that I have find VI example "CAN Waveform Input and DAQmx Waveform Input.vi". The two card use RTSI.
For a reason that I don't understand, Labview craches randomly (1 time each Ten running).
The crach appear randomy few time after the reading of data (after about 100 reading).
All the day I have take time to understand what append :
- I have copy the program in new VI
- I have  check that there is no error
- Check that no empty data where returned by CAN measure....
My program use also Frame method : It work fine.
Using channel method whith the same program cause crash
What is best method to understand what could crash labview ?
Thanks for any idea....
Regards
(6,449 Views)
Dear All,
I'm already searching why LabView Crashes.
I understand what cause the crashes of labview.
In my program, it is possible to change the sample Rate.
For my test I have put in a While loop functions : "Init Daq Card", then "read" CAN and analog measure during 3 second, and close all.
At first iteration of my while Loop at X sample/s = OK
At next iteration of my while loop with a different sample rate : Labview crasches... And a message appear Not enought memory.
Any idea to avoid the crash of laview ?
Maybe this problem is solved in new version of NI CAN. But higher version of NI CAN 2.6.3 compatible whith labview 8.2.1. NI CAN 2.7 seem to be available but I don't know where to download it...
Thanks for reply.
(6,432 Views)
After 2 day to try to understand what append, I finally stop.
I have modify completly my program to avoid using Channel method...
(6,417 Views)
