CAN FD example with labwindows CVI
hello,
i am try to setup CAN FD with PCI8513, any example for labwindows CVI?(how to write, read, etc.)
(1,835 Views)
Do you happen to work with Josip_?  They asked a similar question but with C yesterday.  The answers there are likely applicable, in that very little extra work needs to happen to take a CAN example, and use it in CAN FD.  If it is signal based sessions you just need to update the database.  If it is in memory sessions you need to set that it is an FD IO Mode, and the FD baud rate.
(1,810 Views)
No, i think it just happen we all need this.
i try to setup as my understanding but i have issue to implement, so i want to know if any example for CAN FD base on CVI source code.
(1,793 Views)
