CAN Filter
Hi all !
I use a PXI-8464 2 ports CAN cards, and i want to set the filters. So i searched in the Labview examples and i found the "Series 2 Filter" example. So this example seems to works fine, but here is my question: It seems that when you select the mode single standard, the filter only applies to standard arbitration IDs, and when you select the mode single extended, the filter only applies to extanded arbitration IDs... So thta's sound quite normal, but how is it possible to create a filter that will block standard AND extended  IDs ????
Thanks for your future answers ...
(3,564 Views)
Ooops.. sorry for this stupid question... i understood how it works! The example is good and it works like in the example ! Smiley Wink
(3,562 Views)
