CAN Protocol standards
Hai all,
Am in need of information on following CAN protocol variants.
ISO 11898PT- 1 : 2003
ISO 11898PT- 2 : 2003
ISO 11898PT- 3 : 2006
ISO 11898PT- 4 : 2004
ISO 15765PT- 1 : 2004
ISO 15765PT- 2 : 2004
ISO 15765PT- 3 : 2004
ISO 15765PT- 4 : 2005
SAE J2284-1 :2002
SAE J2284-2 :2002
SAE J2411-1 :2002
ISO 11421
Please help me in knowing the difference between the protocols and whether NI CAN does support the above.
Any help on this is great.  Please help as soon as possible
With best regards,
JK
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(7,227 Views)
Hi JK1,
The following protocols are supported by NI CAN hardware and software.
11898
15765
J2411
The ISO 11898-1, 2, 3, 4 refer to the standardized transport layers.
The same is true for 15765-1,2,3, 4 and J2411-1,2.
The other protocols are not supported.
The manuals for the product will explain what CAN protocols are supported for that product.
Are you using any specific NI-CAN hardware?
I hope this answers your questions.
Christian A
(7,197 Views)
Hi Christian
The NI Module we r using is NI 9853 High Speed CAN.
Is the NI CAN drivers that comes along with the device driver CD is compatible with all the above protcols, or is there any other .lib required to communicate with all these Protocols
Please reply ASAP
Regards
JK
With regards,
JK
(7,179 Views)
Hi JK1,
Yes, the NI-CAN drivers work with the three above-mentioned protocols. For additional information on the API and drivers that come with NI-CAN, you may reference the NI-CAN Hardware and Software Manual and Specifications.
Happy holidays!
Warm regards,
pBerg
(7,145 Views)
To get this right,  NI-CAN is compatible with ISO 15765, but only in terms of acting as the transport layer. The NI-CAN API allows you to program your own diagnostic api, because there is no specific api for diagnostic protocolls available. if you need a ready to run api see the following Link for additional Toolkits, you can use with NI-CAN together.
http://www.ni.com/can/
DirkW
(7,138 Views)
