CAN Send and Receive
Hai
I attached my VI
i can send data by reading the data from a file or by clicking the LED indicator or the default value
if i click send the data will send to my hardware through the CAN
but i should read the transmitted data from my hardware always, when my program starts it should read the data transmitted by the hardware
if i send the data that data should be transmitted to the H/W till i send the next data.
example if i send ON data to my relay the relay should be ON
till i send the next data as OFF or ON
i attached my program, please give me an idea to do this
I am using LabView 7.1
thanks
sasi
(3,522 Views)
hi,
This sounds like you need two threads for your application, one for Read and one for write.
I modified your VI to do so.
Hope that helps.
DirkW
(3,516 Views)
