CAN & CANopen
Hi All
In one of the application i have to read the bus data and also the SDO message. So I am using CAN functions (Frame API) and CANopen functions in the same VI  .Problem is that for CAN frame API as well as CANopen functions i have to configure the CAN device (using both CAN Frame API & CANopen functions). So i am getting error.
Please tell me can we use CAN functions (Channel or Frame APIs) & CANopen Labview Library in the same VI. If yes then how ?
I had made one VI in which before entering the main loop i am configuring the CAN device using CAN frame API as well as  CANopen functions parallely.
Please reply
Thanks in advance
J
(4,065 Views)
Because the CANopen Library is based on the Frame API from CAN, it configures the CAN Port internaly. Because it creates a handle which is not useable with the Frame API functions, there is no way to use both Frame API and CANopen API on the same port.
DirkW
(4,051 Views)
