CAN connection realated to #7354287
(1) PCI-CAN/xs3 CAN card, pint 3, 5, 6 connected.
(2) Common  mode noise of 125V pulse damage the card.
Reason?
(5,913 Views)
Hey there,
Thanks for posting on the Discussion Forums! I understand that you are working with an Applications Engineer on this already. I will let him take care so you can get the answer from our R&D department.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(5,888 Views)
