CAN data transmit for a particular time interval
Hai
     I am using PCMCIA CAN card
In my program i am transmiting CAN data every five second,
When i click "TesterPresent" check box the data assigned is transmitted for every 5 sec till i select "Select" button. when i select "Select" button the loop will end
the other option i have in the program is to transmit the data by enter the data in the "TxMSG" control & by click on "Test 1" button the respective data is transmitted for every 5 seconds till i select "Select" button.
but when i select the "Select" button it takes some time to stop the loop.
I attached my program, please help me to solve this.
I am using LabVIEW 7.1
thanks
SK
(4,049 Views)
Please don't start the same thread twice. See my previous answer.
(4,041 Views)
OK, it was not in the same board. Please ignore my comment !
(4,039 Views)
I had a look to your VI and changed the state machine search case, because this leads some time to wrong results with local variables.
Now both tester present and Tester 1 should end within the same time but it takes at least 5 seconds because of your wait.
Be careful with local variables in the future, try to avoid them when ever possiple.
DirkW
(4,036 Views)
