CAN driver problem
I have developed an application in Labview 8.0 to interface with CAN bus.My application sends some 4 to 5 messages at every 200ms and receives messages at every 400ms.The CAN card which i used is PCMCIA series 2 Low speed card.I have installed CAN driver 2.5.2.
When i am executing the application continuously for 1hr it gives me an error like this
Error -1074388990 occurred at an unidentified location
Possible reason(s):
NI-CAN:  (Hex 0xBFF62002) An internal error occurred in the NI-CAN driver.  A description is located in the file NicanErr.txt in your ..\NI-CAN\bin folder (typically located at C:\Program Files\National Instruments\..).  Solution:  Email or fax the NicanErr.txt file to National Instruments for technical support.
I herewith attached the nicanerr.txt file.If i probe after wirte message i am getting an error like this
NI-CAN:  (Hex 0xBFF62103) The firmware of the CAN or LIN hardware no longer responds to commands from the Windows driver, usually due to frequent CAN/LIN or timer interrupts. Solution: For CAN, use comparator/mask (filter) properties to reduce received traffic.
can u tell me what might be the reason for this ASAP??
Regards
Rajameenatchi
(6,595 Views)
Duplicate Post
Simran K
(6,574 Views)
