CAN error with Channel API
Hello All,
Right now i am facing a CAN error when run my script which was developed using channel APIs. I am not able to trace out the the reason of the error. Pls find attached code and Error description. I have uploaded the sample code here and I am writing several messages in the same VI as same like in the code. Pls guide me in this
Thanks in advance
Anoop
(4,615 Views)
Hi Anoop,
Is the code you posted the exact code you are using when you get the error?  The reason I ask is, usually this error is associated with using the Set Property VI after the interface has already been started, such as in a loop.
Are you able to use any examples from the Example Finder successfully? (Help > Find Examples)  You can Browse to CAN examples by clicking Hardware Input and Output > CAN > Channel API.
Hope this helps!
Adam W
Applications Engineering
(4,593 Views)
hi Anoop,
Since I am not having version 8.0,i am not able to view the code.Since i have faced the same issue and solved it ,i suggest you...
Restart the Pxi-chasis...
each and every time when u r stopping the program..you should clear  the can resources using Task clear...i.e if not ur hardware will still running behind and when u try running vi again at this time it will show the error you mentioned..
(4,511 Views)
