CAN hardware
Hi All ,
I have two Non NI CAN hardware i.e. Intrepid CAN hardware (i.e. ValueCAN3) & Vector CAN hardware (i.e. CANanylzer). Can I use these hardware with NI LabVIEW 8.5. Is NI CAN API are compatible with these hardware ?
Thanks in Advance
HKT
ValueCAN3:- http://intrepidcs.com/catalog/product_info.php/cPath/21/products_id/103
VectorCAN:- http://www.vector.com/vi_cancase_xl_en,,223.html
Message 1 of 11
(15,715 Views)
Hi All,
It is possible to communicate with ValueCAN using Labview. You need to install neoVI driver & there are few example available at intrepids site, which can be used for read/ write CAN port. Value CAN is USB high speed serial communication., so you need to check in which COM port it is adding to you system.
Also vector provide Labview driver for the CANcaseXL.
HKT
Message 2 of 11
(15,691 Views)
do you have Labview 8.5 Exemple to read//write on CANCaseXL ?
Vincent
V-F
Message 3 of 11
(15,656 Views)
I have a CANcaseXL and I want to build a small program to send and receive a few CAN frammes, but using the Vector LabVIEW Library I get "No license" error.
Is there a way to comunicate with this device without the Vector LabVIEW Library? I don't know my license key.
I apreciate all the help.
Daniel Coelho
Daniel Coelho
VISToolkit - http://www.vistoolkit.com - Your Real Virtual Instrument Solution
Controlar - Electronica Industrial e Sistemas, Lda
Message 4 of 11
(15,536 Views)
I called the technical support of the canCaseXL, and It is a non free option... I don't think that it is possible to use this card with Labview without paying anything !
I hope it's a mistake !
Let me know if you can solve this problem !
Vincent
V-F
Message 5 of 11
(15,532 Views)
Is there any other way to build a program for the CANcaseXL device without LabVIEW? Using LabWindowsCVI or simple ANSI C or Visual Basic.NET?
Daniel Coelho
Message 6 of 11
(15,530 Views)
I managed to put my hands on a VECTOR CD where I could find some libraries to be used with C++, C# and VB.
There are also some examples on how to implement a simple code with those libraries.
I had a confirmation from VECTOR that LabVIEW Library is paid.
I hope that these libraries are as easy to use as LabWindows CAN Libraries 🙂
regards.
Daniel Coelho
Message 7 of 11
(15,489 Views)
I have same kind kind of query:
I want to know how we can use the "XL driver library" with "Labview" to send/ receive CAN commands.
Could you please provide any example vi for the same.
Thanks in advance.
Message 8 of 11
(13,020 Views)
There is now a reasonably complete wrapper library for the vxlapi.dll uploaded to the NI Developer Community.
You may wish to have a look at it if you're developing for the Vector XL hardware.
https://decibel.ni.com/content/docs/DOC-30180
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 9 of 11
(12,510 Views)
i  have a valueCAN3 hardware(Usb to CAN), i want use labview perform the hardware, how i can find the reference document. and download it.
Message 10 of 11
(7,974 Views)
