CAN-interface in a Panel-PC
Hello! I installed a high-speed-CAN interface in a Panel-PC. After I shut down the computer it is not possible to start it again immediatly. I have to wait about half an hour before it can be started again. Why? Thank you!
(3,958 Views)
If this behavior only happens when your CAN card is installed in your computer, your CAN card was probably damaged and may need to be sent in for repair. If this is the case, you should go to www.ni.com/ask and fill out a phone support request.
(3,958 Views)
