CAN message layout for transmit
Hello all,
I am working on transmitting a CAN message but cannot get a confirmation about the changes. I construct the payload, identifier and timestamp on the CAN frame but cannot seem to get the confirmation ID when I run the device.
I use two codes; one for transmitting and one for running/logging/data plotting with different database files[0x200 for transmit and 0x201 for confirmation of change with can_database_ch0 file whereas my output frames are 0x513, 1536, 1793 and 1794 with respect to another .dbc file]. Is this an issue?
I want to verify if my method of constructing CAN frames are correct and if the method is valid?
If not, how do I merge the functions to write, read and log at the same time?
Any advice would be helpful.
(5,850 Views)
Accepted by topic author Red43
Figured it out.
Thank you
(5,821 Views)
