CAN moitoring Tool
Hi ,
 I am Testing Engineer and i need to do CAN moitoring Tool which monitors CAN messages , sent from the Controller .
 I cannot use the Lab view example as it it since i have Can Case XL and i dont have NI cards , i need to do the CAN monitoring using Vectore drivers ,
Can Any one tell me that how can i develop CAN monitoring Tool which monitors CAN message sent from controller , using Vactor drivers , calso please explain how does the code work ,
kindly explain this since this is urgent
thanks in advance ,
(7,027 Views)
Take a look at this thread - http://forums.ni.com/ni/board/message?board.id=30&message.id=4141&query.id=1251531#M4141
It appears that you have to purchase the driver from vector to do this.
(6,970 Views)
thanks for the links , i didnt find much information in this , we have paid for vector lib , can you please give me some more links of threads or more information , so that i can use vectore lib for CAN caseXL and labview 8.5 for CAN monitoring , waiting for your reply ,
(6,961 Views)
Caution: Novice-speak below
Kindly clarify the following: What kind of card do you have? PCI? USB? PCMCIA? With the Vector h/w and driver s/w, did you receive example VIs and/or dlls? It seems these are available (and that you do already have something of that sort 🙂 )
I'm attaching the manual for version 1.3 of Vector's LV API and it seems pretty straightforward. Do you own this beautiful piece of software?
Vaibhav.
(6,944 Views)
