CAN object open
Hi All,
In my application using labview it is required to change the bitrate during the execution of the code.
Many a times I am getting Port ant Object Handle problem.
Can anyone please help me in dealing with these Handles.
I have attached the image of the sub Vi I am using to write the New bitrate along with the NI spy file.
also how to interpret this .spy file.
Thanks in advance.
(6,938 Views)
Please let me know if any further explanation is required from my side.......
Thanks...
(6,929 Views)
Hi AAG,
One thing what you can do is temporarily stop the CAN task handle and modify your bit rate and restart again. Hope this will solve your purpose.
MRK (CLAD)
(6,781 Views)
Thanks for ur reply.......bt that problem is already solved.......
(6,771 Views)
