CAN read output showing different arbritration ID than sensor sends
I am facing a very weird problem. I am building an application to read and log the CAN data from the angle sensor. I am able to do all the things that I want to.
But the problem is my sensor is sending CAN data with extended arbritration ID 0x18F01DE4 but in my LV application when I read it it shows 0x38F01DE4.
I cross checked it with MAX also and it shows the right ID i.e. 0x18F01DE4
Does anyone knows the reason behind this?
regards
swap
(6,599 Views)
This is normal for the older CAN api. It shows the message is an extended message by adding 0x20000000
(6,588 Views)
correct. and well documented in the NI-CAN manual P11-47 😉
ArbitrationId = Returns the arbitration ID of the received data frame. The NCTYPE_CAN_ARBID type is an unsigned 32-bit integer that uses the bit mask NC_FL_CAN_ARBID_XTD (0x20000000) to indicate an extended ID. A standard ID (11-bit) is specified by default.The Network Interface receives data frames based on the comparators and masks configured in ncConfig (including the Series 2 Filter Mode attributes).
(6,583 Views)
thanks ...............solved the problem....:-)
(6,578 Views)
Thanks are given with kudos and marking the solution to a post when applicable.
(6,574 Views)
