Hi Halvor,
Attached you will find an EXE file for a LabVIEW program which reads the manufacturer device name (1008h) using CANopen SDO transfer.
Adjust the Node ID and the CAN Port to fit your needs and run the program. If it works , then your device should be ok if not contact the device support.
What the program does is : 1. Initializing every device in the network to the NMT preoperational state to use PDO communication. (COB ID = 0, First Byte = 128, Sec. Byte = 0)
2. Write the SDO Request ( SDO tx =601h + node ID, First Byte = 40h, Sec. Byte = 8h, Third Byte = 10h, Fourth Byte = 0)
3. Wait for Transmit success
4. Read the SDO Answer (SDO Rx = 581h + node ID, the answer comes in Hex values and can be translated to ascii strings)
5. Stop the Communication using the NMT Stop Command. (COB ID = 0, First Byte = 2, Sec. Byte = 0)
Hope that helps.
