CAPL browser shows that the .can file is write protected while it is not and keeps toggling, CPU performance reach 100%
The problem is when I open the CAPL browser, the CPU load increases to 99~100%, and the .can file I am editing can't be saved, and I keep getting the message "file is protected and can't be saved". This happened on multiple machines with different CANoe versions.
I tested on these versions:
8.0.36
8.0.71
8.0.93
8.1.60
Randomly the icon of the "write protected" appears beside the file name in the file tab inside the CAPL browser, if I could press the save button while it is not appearing the file is saved, other wise I get the error message. The memory usage is also increases too much and then the browser stop responding.
Do any body had the same issue before? any advice?
Operating system: Windows 7 Ultimate 64
AntiVirus installed:  McAfee
(6,486 Views)
Hi Allaithy,
Can you clarify how is this issue related to NI CAN products?
Anyway, here are some things to try:
  • Is this the file on a network? Do you have administrator privileges to this network?
  • Is file set to Read-only?
(6,463 Views)
Hi Miro_T,
It is a local file on my machine and I have full admin rights on it. It is also not a read only one. I still can't figure out the source of issue.
I was suspecting that it is related to the new installed McAfee on my enterprise machine, seems to have a problem with the CAPL browser. I found that all my collegues who have that update are also affected!!
(6,439 Views)
