CCP command to ECU using Vector CAN cardXL
Hello ,
I want to know ECU measurement and calibration tool kit support Vector CAN CardXL.
How to communicate to ECU using CCP command using Vector CAN cardXL in Labview 8.0.
(5,279 Views)
No, the toolkit does not support Vector products. It only supports NI boards.
DirkW
(5,274 Views)
Thanks for ur reply DirkW,
any one can suggest me how to communicate to ECU using  CCP commands from Labview and Vector CAN cardXL.
(5,255 Views)
Hello all,
To communicate to ECU using CCP command and Vector CAN cardXL from Labview 8.0 do we need to create CCP driver for Labview to send commands and receive response from ECU.
Thanking all
(5,250 Views)
You may want to contact Vector to see if they have a library or DLL that will communicate with this protocol. If they have a DLL that is already developed, you can call the function from the DLL using a call library function node. Otherwise, you will have to develop the code necessary to communicate with the ECU using CCP commands. I hope this helps!
Missy S.
Project Engineer
RoviSys
(5,180 Views)
