07-22-2010 09:55 AM
I am (as before) trying to CCP connect to our product ECU. After establishing the CRO & DTO ids form the A2L file, I try to connect. At this stage I get error -301021, that the seedkey dll could not be loaded. We don't use seedkey dlls. The parameter is not initialised in the database. How do I get round this? We do use a map file (.elf or other file format). Is this required?
As I don't have any error management in the code at the moment, some later commands are actioned. Using CANalyzer to monitor CAN bus activity I can see outputs from my code using the MC Generic CCP command block, and matching responses from the ECU. However LabView is not outputting any of the responses back to me. Is tis because of the error upstream, or some other reason?
Ian
07-22-2010 11:17 AM
Oops, it seems that for this latest ECU, we are now using a seedkey dll! I humbly apologise...
