04-16-2007 05:17 PM
04-17-2007 12:55 PM
04-17-2007 01:51 PM
0xBFF62001 (Timeout error) when attempting to write using Write Devicenet IO.vi. Do you know if in fact the NI PCI card can work at that speed if the baud rate did not change (125k)? Thanks
04-17-2007 11:10 PM
04-18-2007 09:28 PM
04-19-2007 01:51 PM
I ran CAN and got the following CAN information (new device first). Is it possible that the NI-dnet card (CAN controller Intel 82527 and Philips 82c250 transceiver) is just not able to handle the new CAN transmission rate (1.45 Hz)?
I was able to establish communication with a SST card (SJA CAN controller and TJA transceiver)
Thank you.
04-20-2007 12:53 AM
04-20-2007 09:37 AM
