Can Signal-Frame Conversion Issues
Having issues with converting a signal (float) to a can frame using a dbc file. I am using two methods, xnet and Hooovahhs. Using xnet I can convert the positive and negative to a correct can frame. Using code inspired by Hoovahhs example I can only convert positive signals correctly and negative signals are converted to all zeros. Including example project/code/dbc file. Any ideas on what I am doing wrong?
J-
(4,369 Views)
If you don't get a response, I suggest you post your example in a version of LV prior to 2023 to allow more users to open it.
(4,340 Views)
Sorry I only have access to LabVIEW 2022 Q3, so I can't open it.  Still you aren't the only one that suggested my frame signal conversion had an issue with negative numbers.  I made a post where the code was originally developed.
https://forums.ni.com/t5/Example-Code/CAN-Frame-Signal-Conversion/tac-p/4189168/highlight/true#M1489...
I was waiting for feedback from other users to tell me if that fix addressed their issue.  If it does I planned on releasing a new version with the fix.  Assuming this is the correct method, I need to make a new release of the package, and that example post.
(4,301 Views)
Sorry went on vacation. Here is a modified version
Thanks for you blog. I have learned so much.
J.-
Positive number
Negative
(4,189 Views)
Thanks so much for the demo, it was very helpful.  I did find a bug in the conversion but now I have a working set of code that functions correctly. I just need some time to update packages and test a few things.  The last post I made had a set of code that mostly works but has one edge case not handled correctly.
(4,124 Views)
(4,078 Views)
