Can bus activity
Hi all,
I'm using all ports of a PCI series 2 CAN card and I would like to monitor the bus activity using without opening bus monitor.
Does anyone know how to detect if the CAN bus is still sending messages or not using channel-API?
Sometimes the bus seems to freeze after a while and not showing any changes at all. I have to stop the vi and run again to see the change value.
I am trying to read lots of messages (each contain maximum 64 channels). I use Multi-Chan Single-Samp 1D Dbl type to read.
Thank you
-bm-
(3,660 Views)
Please direct all replies to the following post:
http://forums.ni.com/ni/board/message?board.id=30&message.id=1457
Logan S.
(3,649 Views)
