03-25-2003 06:35 PM
03-26-2003
11:07 AM
- last edited on
09-24-2025
12:10 PM
by
Content Cleaner
Hi LV,
The power settings on the PCI-CAN only affect the board's transceiver. The board will not provide power to the bus. If you have a node that needs power from the bus, you need to have a power supply that provides power to those lines. The setting of the PCI-CAN jumper has no effect on this.
DiegoF
