Can full duplex mode
How can I Configure the CanBus card for full duplex mode of communication?
I have          series 2 , dual port 9 pin Rev C                PCI card
Thanks ahead
(5,226 Views)
Can you clarify what you mean by "full duplex"? Are you using high speed or low speed CAN communication?
Missy S.
Project Engineer
RoviSys
(5,209 Views)
I mean : Can I make such configuration of PCI card (CAN series 2 with two ports CAN_0 & CAN_1), that I will transmit messages(from PC to Unit ) on CAN_0 and receive messages(from Unit to PC) on CAN_1 .
Thanks ahead
(5,202 Views)
Yes, this should be possible. You will have to configure the cabling based on the speed (high speed or low speed) your device and CAN card are communicating with. Here is a link to termination for both speeds of communication. I hope this helps!
Missy S.
Project Engineer
RoviSys
(5,189 Views)
